Alpha-numeric Numbers Display
- Status
Hello
I want to display Alpha-numeric Numbers on screen but I am not getting number on screen
8051- keil - LCD 16*2
Please look at design and program. whats reason why Its not working?
Code C - [expand] |
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
| #include<reg51.h>
#define Data_Port_Pins (P0)
sbit Register_Select_Pin = P2^0;
sbit Read_Write_Pin = P2^1;
sbit Enable_Pin = P2^2;
sbit Column_1 = P1^0;
sbit Column_2 = P1^1;
sbit Column_3 = P1^2;
sbit column_4 = P1^3;
sbit Row_1 = P1^4;
sbit Row_2 = P1^5;
sbit Row_3 = P1^6;
sbit Row_4 = P1^7;
void delay(int a)
int i;
for(i=0;i<a;i++);
/* send data */
void LCD_Data (unsigned char Data)
Data_Port_Pins = Data;
Register_Select_Pin=1;
Read_Write_Pin=0;
Enable_Pin =1;
delay(150);
Enable_Pin =0;
delay(150);
/* Send command */
void LCD_Command (unsigned char command)
Data_Port_Pins = command;
Register_Select_Pin =0;
Read_Write_Pin=0;
Enable_Pin =1;
delay (150);
Enable_Pin =0;
delay(150);
void LCD_Initialization(void)
delay(15000);
LCD_Command(0x30);
delay(4500);
LCD_Command(0x30);
delay(300);
LCD_Command(0x30);
delay(650);
LCD_Command(0x38); //function set
LCD_Command(0x0c); //display on,cursor off,blink off
LCD_Command(0x01); //clear display
LCD_Command(0x06); //entry mode, set increment
void Return(void) //Return to 0 location on LCD
LCD_Command(0x02);
delay(1500);
void Port_Initialization(void)
P0 = 0x00; //used as data port for LCD
P1 = 0x00; //used for generating outputs and taking inputs from Keypad
char READ_SWITCHES(void)
Row_1 = 0; Row_2 = 1; Row_3 = 1; Row_4 = 1; //Test Row 1
if (Column_1 == 0) { delay(10000); while (Column_1==0); return '1'; }
if (Column_2 == 0) { delay(10000); while (Column_2==0); return '2'; }
if (Column_3 == 0) { delay(10000); while (Column_3==0); return '3'; }
Row_1 = 1; Row_2 = 0; Row_3 = 1; Row_3 = 1; //Test Row B
if (Column_1 == 0) { delay(10000); while (Column_1==0); return '4'; }
if (Column_2 == 0) { delay(10000); while (Column_2==0); return '5'; }
if (Column_3 == 0) { delay(10000); while (Column_3==0); return '6'; }
Row_1 = 1; Row_2 = 1; Row_3 = 0; Row_4 = 1; //Test Row C
if (Column_1 == 0) { delay(10000); while (Column_1==0); return '7'; }
if (Column_2 == 0) { delay(10000); while (Column_2==0); return '8'; }
if (Column_3 == 0) { delay(10000); while (Column_3==0); return '9'; }
Row_1 = 1; Row_2 = 1; Row_3 = 1; Row_4 = 0; //Test Row D
if (Column_1 == 0) { delay(10000); while (Column_1==0); return '*'; }
if (Column_2 == 0) { delay(10000); while (Column_2==0); return '0'; }
if (Column_3 == 0) { delay(10000); while (Column_3==0); return '#'; }
return 'n'; // Means no key has been pressed
char get_key(void) //get key from user
char key = 'n'; //assume no key pressed
while(key=='n') //wait untill a key is pressed
key = READ_SWITCHES(); //scan the keys again and again
return key; //when key pressed then return its value
int main(void)
char key; // key char for keeping record of pressed key
Port_Initialization();
LCD_Initialization(); // Initilize LCD
while(1)
key = get_key(); // Get pressed key
LCD_Command(0x01); // Clear screen
LCD_Data(key); // Echo the key pressed to LCD
- Status
