Allegro PCB Editor and OrCAD PCB Editor
chrismhyao
Newbie level 3
dbdoctor allegro
I am confused between the two.
I am using OrCAD PCB Editor and my layout house is using Allegro; sometimes I got error message of 'database revision 14.x is too old ... must run dbdoctor' by trying to use the layout house' library. Does anyone know what is going on? and how can I make this work.
I also tried to convert the library using dbdoctor, but not all of conversion works.
allegro dbdoctor
Regarding confusion,
It is created by people loosely referring to Capture and CIS as "Allegro Schematic".
Cadence bought OrCAD (both Capture and Layout tool) some years ago
Capture is used and some how integrated as front end tool for creating netlist to ALlegro.
Recently Cadence dropped further development for Orcad Layout.
In addition native schematic tool for Cadence is Concept.
Now regarding error you are receiving, as you have not mentioned which version of Allegro you are using, judging by your post looks like is 15.XX or above if your layout house uses version 14.XX or lower then you have to run DB Dr. to upgrade to higher version.
I have never encounter any issue running DB Dr. Always worked fine.
HTH,
M
    chrismhyao
orcad pcb editor
thanks for the detailed info.
Regarding the database version update, do you know if there is anyway that I can update all my libraries to the latest version using dbdoctor?
orcad dbdoctor
No problem,
From programs menu go to "PCB Editor Utilities" then "DB Doctor".
You can use wildcards to grab all libs or brds.
Regards,
M
    chrismhyao
The best option is go to Tool and run the data base check it will work 100%..
Praveen Bhat
Praveen Bhat
If the board file is of the older version like 14.x and you are trying to open that in 16.x then the above suggested option do not work.
You have to go to the Start>Programs>cadence SPB 16.2> PCB Editor Utilities>DB Doctor select the board or library files and run update.
After that it will work fine
Why cadence has Two differnt PCB editors ? since both orcad & allegro comes under same tag i.e. "Cadence"
Why dont cadence make an one universal powerfull tool for PCB design?
what is the difference between both editor ? which is the best ?
Because for each new version software they are updating some new features...as technology grows they also have to modify the tool also.
Praveen
