hi i have problem while importing orcad capture to allegro spb 16.3 layout.after import and packaging symbols to foot print in allegro i can see the component in place mode but it is not going to place.
so please tell me what is the right process to save pcb footprint in library of allegro 16.3 that after packaging i can place the component in layout easily.
1) you have to check whether right footprint name given in schematic.
2)Check the .PAD and .PSM path some time flash file will be on..that time you have to go to pad designer remove the flash.(flash is used to thermal pads..)
in the componant place mode if you see the componant but if doesnot get placed.
see the command window below.it will display an error why it is not placed.
there might be pin number mismatch or you would not have placed .psm & .pad files
alternate way to find the error is import the orcad capture netlist again.
netrev report will be generated in the working folder. it will display the errors why the symbols are not placed
