Allegro- How to identify Unplaced nets??
Prince Moses
Member level 1
Bangalore
Hi mate...
I am using allegro 16.2 pcb editor, where i have designed one small circuit. i have completed up to tracing. here but only one net is missing without placing which i couldnt identify.. plz help me to solve this issue. thank u so much..
Prince
prasguy
Member level 1
Bangalore, India
Hi Prince,
That is not possible either the net is not present in netlist or you have set no rats property. You can check 100% routability through setup - Drawing options.
Regards
Pras
Prince Moses
Member level 1
Bangalore
hi sir..
I thank u so much for your immediate reply.. While following this path, display--> status, it s showing that layout has one unrouted net.. where can i check 100% route availability?? Plz show me the path.... thank u so much..
Prince Moses,
prasguy
Member level 1
Bangalore, India
There is icon on top left side, click that,, It is Rats-ON,, that will display un-routed net or try to generate report for un-connected pin report (Tools--> report) and chk
