Allegro Design Entry CIS 16
Hai ranjith_r,
I also faced like this problems when i starting working on Allegro, you are given all your paramenter setting except LIB.
The footprint name of yours is RES0402, So your should have a 0402 lib with the same name. Check are you configered your lib with that footprint.
For better performance, for each porject keep a seperate LIB.
then configure that lib to that PCB job.
Make sure your all PAD and PSM Paths should be in the same LIB folder.
Thanks & Best regards,
R. Balasubramaniaraju
    ranjith_r
Dear Bala,
Thank you for the information.
Since i am new to this tool , some facts are not clear !
But could you please help me in configuring to footprint and PCB.
What is the PAD and PSM Paths.
Thanking you
Ranjithr
