allegro brd file and orcad capture interlink
samym
Member level 4
india
hi,
i am using allegro 16.5 .please tell me how to interlink orcad schematic and allegro brd
I am not understanding what you mean by interlink, Steps involved are; create schematics-->assign footprint for each component in the schematics-->check for DRC error if any-->create netlist for your schematics-->choose the option 1)open the allegro after netlist creation 2) do not open the allegro after creation of netlist--> if select first option, the allegro ll automatically open once your netlist created irrespective of the warning or error--> if you select second option the allegro will not open after your netlist creation irrespective of the warning or error.--> once the successful creation of the netlist in allegro go to file--> import--> choose logic from the list-->pop up will come there select the from design entry CIS (capture)--> browse for the netlist that you created before--> click on import, then all your components are ready place into your board. -->go to place menu and select the place manually and you can place the components where ever you want.
Thats it.
Regards,
Patil
hi,
i have opened both schematic and brd file ,if i am selcting some parts in schematics means automatically these parts should be higilited or selected in allegro brd file (cross probing)
We must enable Intertool communication from miscellaneous Tab From Options>Preferences Menu
hi,
thanks for your help,its working now
I have the same problem, have you found a solution to enable interlink ?
Some times you need to save your schematic and then re-export the netlist to your board in order for the intertool communication to work, I have never been able to figure out a pattern for this issue on my machine but it just comes and goes and I even sometimes have to restart my machine.
but for most cases, i just need to re-export the netlist to the board file
