Allegro board outline
jeremyz
Newbie level 3
Is it possible to make a board outline in Allegro with 45 degree lines? When I go to Shape > Outlines > Board Outline, it doesn't seem to let me use anything other then 90 degree angles
you can also use Add->Line to add/change board outlines, you can change the "Line Lock" to "line 45" or "arc" in the Options tab of the Control Panel.
