all the parallel ports not working in p89v51rd2 (8051)
cse_muthu
Newbie level 3
Newbie level 3
hi,
i am new to embedded programming. after i flashed a serial program to make serial communication between two 8051 MCUs in both of my MCU, the parallel ports(P0,P1,P2,P3) are not working. even after flashing a new program no output in any port of both the MCUs.
the code i have used in sender 8051 is
given below :
#include<REG51.h>
unsigned char a;
int i;
void front()
unsigned char b=0x0a;
SBUF=b; //place value in buffer
while (TI==0); //wait until transmitted
TI=0;
void back()
unsigned char b=0x05;
TI=0;
void left()
unsigned char b=0x02;
TI=0;
for(i=0;i<=10;i++);
SBUF=0x00; //place value in buffer
TI=0;
void right()
unsigned char b=0x08;
TI=0;
for(i=0;i<=10;i++);
TI=0;
void stop()
unsigned char b=0x00;
TI=0;
void fire()
TI=0;
void off()
TI=0;
void main()
P0=0xff;
P2=0x00;
P1=0x00;
P0=0x00;
TMOD=0x20; //use Timer 1, mode 2
TH1=0xFD; //9600 baud rate
SCON=0x50;
TR1=1;
while(1)
a=P0;
if(a==0x01)
front();
else if(a==0x02)
back();
else if(a==0x03)
left();
else if(a==0x04)
right();
else if(a==0x05)
stop();
else if(a==0x06)
fire();
else if(a==0x07)
off();
else
stop();
The above program not worked for me.
the receiver side program is
given below:
#include <reg51.h>
void main()
unsigned char mybyte;
SCON=0x50;
TR1=1; //start timer
while(1)
{ //repeat forever
while (RI==0); //wait to receive
mybyte=SBUF; //save value
P0=mybyte; //write value to port
RI=0;
the receiver side program also not working.
i cant find any problem.
even after erasing all flash in two 8051s,the new program that flashed for checking port also not working.
the new program that i used is given below.
#include<reg51.h>
void main(void)
while(1)
P0=0xFF;
the above program doesn't give any output on port0 pins.
the two mcus are not responding to even very simple program like above.
any software reset should be done.
I also attached the project source files in this thread. link to the source file: View attachment keil.rar
i really need help to resolve this issue.
no you are not wrong. i also used the code for other ports also. not working. any suggestions?
I´m not sure if you understood the neeed to debug the problem at the lower level.
Anywaym try to invert values and see if output invert :
P0=0x00 ;
