jony4u
Newbie level 5
How I can divide the voltage to two ports that every port will have 8 bits and the connection will do with the MSB and LSB and I will receive 16 bits ?
the advantage of using oversampling is that you could simply use the existing low resolution ADC (8 or 10 Bits) and apply just algorithms to get higher resolution. A small hardware will also be needed to inject the proper noise to the signal and to reject HF noises. In case the price is important for you you can't go for more expensive uP (like AD or TI) so oversampling is a good solution.
I know that not so many people use it because it's hard for understanding
