algorithm for diagonal motion in xy plane by stepper motor
maham ahmed
hi ,
i have to move two stepper motors simultaneously in XY plane. i am using pic microcontroller 16f877a.
kindly tell me the algorithm to implement this
What have you tried?
1axis control with home position or reference switch.?
Moving from home positions , uses software count of present and.desired position for each axis. therefore you, need 2 counters, present and target difference position.
count down until target difference= 0 or limitswitch is not tripped.
This may be crude but…
X=20, Y=10.
Use float variables to divide the short side by the long side. 10/20= 0.5
Float Yfraction = Y / X
Int oldY=0     // starting place
Int newY
For Xstep = 1 to 20
Step X motor
newY = Yfraction * Xstep         //You have to get around the float to int problem here
	If  newY > oldY	// Integer comparison
               Step Y motor
               oldY = newY		// to be ready for the next increment
Next Xstep
Y will only step when newY increments to the next whole number.
You will have to sort out beforehand which side is longer and positive or negative directions.
This would be more graceful with modulo multiplication but it’s late and I would have to get out the books for that one.
I hope for your sake that someone has a better way.
Look at this: https://en.wikipedia.org/wiki/Bresenham's_line_algorithm
Normally used to calculate pixel positions on graphical displays but the same algorithm should work to find the shortest step route between two coordinates anywhere. The page includes some sample code you can adapt.
Brian.
