Register Log in
AL8860 Ton min
Winsu
Full Member level 2
Hi All,
I am designing a LED board using the AL8860. My application would run from 30V ( Vin max) to Vout of 12.08 at 480mA. I don't have a problem with the nominal current , the problem comes when I reduce the current to a 10%. The datasheet states this:
I have done the calculation when I have 47mA of Iout and 11.04 V of Vo to calculate the Ton and it is less then 500ns( using an inductor of 440uH, which is bigger than I would like to use). Below is the equation:
I wonder if while using analog dimming mode I still have to calculate the Ton to know if the converter would do the switching properly or I just need to make the calculation for my nominal current and how the dimming current is just the 10% of the nominal( datasheet states it dim the current down to 5% ) I don't have to worry about it.
Any help would be useful? .
Toggle Sidebar
