Airconditioner controller !
binu G
Advanced Member level 2
Bangalore
hi ,
can some one explain the concept to control the compressor in the airconditioner
i am surprised will the temperature will alone define the contorl ?
Regards
Binu G
wolly
Member level 3
compessor in an air conditioner is only put ON or OFF according to the temprature reached/required using a thermostst or a temprature sensor
the compressor's only function is to alter the temperature
banjo
Actually, air conditioners do more than just lower the temperature. They also remove humidity from the air. This could be what the original poster was referring to. Sadly, all thermostats and air conditioner controls look at only the temperature, not the temperature and humidity. That is why you have to modify your settings based on the every changing weather. On a warm day with dry air, a setting of 75 degrees may be comfortable. On a very humid day, a setting of 75 degrees may feel like it is still too hot.
