Air Fuel ratio sensor LSU 4.9 sensors interfacing (oxygen sensor)
aliraza786
Full Member level 4
Lahore, Pakistan, Pakistan
Air Fuel ratio sensor LSU 4.9 sensor interfacing ( oxygen sensor )
air fuel ratio sensor used in cars, model LSU 4.9 boash , controller Chip CJ125 , i have searched alot, lots of info is also available but till now i am not able to understand its basic working principle of this sensor, because i want to use this sensor without the Controller chip, i want 0 to 5 volt output but CJ125 gives data in SPI format.
also i am confused in functions of different pin out of this sensor.
Kindly help
ali
Re: Air Fuel ratio sensor LSU 4.9 sensor interfacing ( oxygen sensor )
(1) Do you care about operating away from stoichiometric?
If no, then a simpler sensor and A=5 single supply op amp
is your ticket.
(2) I expect Bosch has some app notes about LSU4 sensors
and their care / feeding. This is not trivial, controlling the
element temperature is key and behind that I'm sure is a
cal-map of some sort.
(3) You would probably be effort and money ahead, to use
something like the NAW kits. I got one some years back and
found it way, way cheaper than my Innovate LM-1 wideband
meter.
I'd start with drilling into Bosch sensor collateral literature
as deep as you can, if you mean to cobble something on
your own.
Hello Dick_dick_freebird thanks for the detailed reply i am just interested in is if i control the temperature by some means then i just want to measure the oxygen content in the exhaust gases. i dnt remember exactly as what is stoichiometric is , but if the pump current is referring to the oxygen content in the exahust gase then i can use opamp to amplifier it, i need little more info about its connection, like which pin of sensor should be connected to which pin of opamp.
Thanks alot for you guidance.
Kind Regards
Ali
Like in this image , shown a pinouts of LSU 4.9
https://www.google.com.pk/search?q=...Pro0b3nxwIVglwaCh112wyu#imgrc=4ockqAKbUlaX4M:
This which pins should be connected to which pins of opamp.
are you suggesting me something Basic opamp circuit.png like this ?
