robismyname
Full Member level 6
- Joined
- Jan 17, 2008
- Messages
- 390
- Helped
- 11
- Reputation
- 22
- Reaction score
- 9
- Trophy points
- 1,298
- Location
- Central Florida
- Activity points
- 4,603
I need help identifying the purpose for the circuit components in the schematic. To the far left (SR_ANTD) is the connection to the antenna. To the right of the antenna connection there is a JFET?-not sure(Q17) keep moving right you will see a Resistor (R139 - 100K) connected to 3.1V, a ferrite bead connected to 3.1V, I believe another JFET?-not sure(Q13). Below the JFET-not sure (Q13) there are two cap's (C184) and (C185) connected to ground and then a resistor (R111) and an inductor (L31).
I have a few question based on the schematic.
1)Are Q17 and Q13 JFets?
2)Why are there two caps (C184 and C185) connected to ground?
3)Why is one .1UF and the other 22PF?
4) Why is the Resistor and Inductor in series?
5)Why is there a 100K resistor located at the AVCC_3.1V?
6)Why is there a Ferrite Bead connected between the 3.1V and JFET? Why not just a resistor or a cap?
I understand CAP's - that is cap reactance Xc = 1/jwC, current leads voltage, stores energy as electric field but I dont understand why it is used the way it is used in this circuit
I understand Induc - that is induc reacteance XL = jWl, Votage leads current, energy is stored as magnetic field but I dont understand
I understand Resistors - no Reactance
I understand complex numbers and impedance (R+jX)
Apparently not too well if I cant figure out the whys in this circuit. What am I missing other than a good brain?
Please enlighten if it not too much trouble.....
