A 5 Watt transmitter for the low band (530 - 750 Kc)
This is a small LP AM transmitter for the low part of the medium wave band. Output power is approximately 5 watts and a BD 137 is used as a final transistor which is powered by a power OpAmp of type A2000. This is a particularly robust OpAmp which is easily able to deliver more than 10 watts of audio at loads of 2.5 Ohm and lower at a 12 - 14 Volt supply voltage. This A2000 is made for 12 - 14 Volt supply voltage but can tolerate even voltages up to 25 volts. From the
output, there may be flows of up to 2 Amps and this is more than sufficient for our final stage. The IC has an overload protection which switches off the output in case of overload and thus de-energises the output stage
The transmitter itself is a three-stage circuit with the BC 550 as oscilator, tuned with a 2 piece BB112 and an additional capacitor
to divide the range into two parts, 530 - 600 and 600 to 750 Kc, the VFO is stabilized with a 78L08, Furthermore, an audio compressor is provided by means of a CB 550 which regulates the input sensitivity when the modulation depth approaches 100%.
A LM741 OpAmp is also connected as Low Pass filter with a cutoff frequency of 4700 Hertz.
The transmitter is coupled with a ferrite transformer, which consists of a vie4rtal windings on a ring core. each winding has a
self-inductance of 22 h. The output of this is connected to an antenna extension coil , the value of this depends on the antenna length. For a wire length of 17 meters I came to 900 uH, by means of a collapsible ferrite core this coil can be tuned to the desired resonant frequency. At 12 volts, this transmitter absorbs about 1 - 1.3 Amps with a good antenna adjustment.
