David_Khalatyan
Newbie level 1
- Joined
- Nov 14, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 11
Hi there,
I'm trying to design a solar charger that will trickle charge a rechargeable 9V battery that will then charge my mobile device as needed. I've got two PV cells, both 1.5V at 240mA. To prevent damaging the device's battery, I'm planning to connect the 9V battery to the circuit from an emergency charger that runs off of 4 AA batteries (2 batteries in series that are parallel to the other 2 in series as far as I can tell). Also, to prevent the 9V from discharging into the PV cells I'm planning on adding a diode. Does this seem like a reasonable/accomplish-able plan? If so, can anyone give me diode recommendations as I'm new to the electronics world and don't understand a lot of the specifications.
Thanks,
David
Thanks,
David
