advace for the 16F877
MARWEN007
Junior Member level 2
advIce for the 16F877
Good evening I want to know is what the pic 16F877 we allow applications to multiplication and division as geometric functions, for example (fct sines and cosines )????
MARWEN007
excuse me well I'm still newbie to praogrammations peak in our case of the 16F877. good question I ask myself the 16F877 I can do simple multiplication and division for example if I have a constant in my program and I will multiply or divs each variable with that i can c? otherwise I will determine a phase shift FI and I calculated the cosine FI? The 16F877 may atteidre these calculations?
horace1
Advanced Member level 5
Norwich, UK
are
Balen (Belgie)
You can use CCSC has built in Funtions
PHP:
SIN( )
COS( )
TAN( )
ASIN( )
ACOS()
ATAN()
SINH()
COSH()
TANH()
ATAN2()
Syntax:
 val = sin (rad)
val = cos (rad)
val = tan (rad)
rad = asin (val)
rad1 = acos (val)
rad = atan (val)
rad2=atan2(val, val)
result=sinh(value)
result=cosh(value)
result=tanh(value)
Parameters:
 rad is a float representing an angle in Radians -2pi to 2pi.  val is a float with the range -1.0 to 1.0.  Value is a float.
Returns:
 rad is a float representing an angle in Radians -pi/2 to pi/2
rad1 is a float representing an angle in Radians 0 to pi
rad2 is a float representing an angle in Radians -pi to pi
Result is a float
Function:
 These functions perform basic Trigonometric functions.
sin
 returns the sine value of the parameter (measured in radians)
cos
 returns the cosine value of the parameter (measured in radians)
tan
 returns the tangent value of the parameter (measured in radians)
asin
 returns the arc sine value in the range [-pi/2,+pi/2] radians
acos
 returns the arc cosine value in the range[0,pi] radians
atan
 returns the arc tangent value in the range [-pi/2,+pi/2] radians
atan2
 returns the arc tangent of y/x in the range [-pi,+pi] radians
sinh
 returns the hyperbolic sine of x
cosh
 returns the hyperbolic cosine of x
tanh
 returns the hyperbolic tangent of x
Note on error handling:
If "errno.h" is included then the domain and range errors are stored in the errno variable. The user can check the errno to see if an error has occurred and print the error using the perror function.
Domain error occurs in the following cases:
asin: when the argument not in the range[-1,+1]
acos: when the argument not in the range[-1,+1]
atan2: when both arguments are zero
Range error occur in the following cases:
cosh: when the argument is too large
sinh: when the argument is too large
Availability:
 All devices
Requires:
 math.h must be included.
Examples:
 float phase;
// Output one sine wave
for(phase=0; phase<2*3.141596; phase+=0.01)
   set_analog_voltage( sin(phase)+1 );
Example Files:
 ex_tank.c
Also See:
 log(), log10(), exp(), pow(), sqrt()
