Help
Advanced Member level 2
Dear All,
I have facing the /PENIRQ problem. I did tried a lot of testing and changing a few ADS7843 and TFT-touch-screen but still no working.
I would like to compare the result with you all.
1) I'm using 3.2" screen. I did measure the touch screen resistance for the X-,X+ is ~300Ohm and Y-,Y+ is ~400Ohm. (without connecting to ADS7843 device)
2) Connect touch screen pin X-,X+,Y-,Y+ to ADS7843 and measure the voltage at point X-,X+,Y-,Y+. (ADS7843 operate at 3.3V and /PENIRQ external pull up 100K Ohm)
No touch on screen:
X+ = 2.315V
Y+ = 2.315V
X- = 0.000V
Y- = 0.000V
/PENIRQ = 3.3V
Touch on screen:
X+ = 2.315V
Y+ = 2.315V
X- = 2.315V
Y- = 2.315V
/PENIRQ = 3.3V
I wonder why the /PENIRQ wouldn't pull to low as per datasheet said once the /PENIRQ is pulled LOW, a voltage typically will not exceeding 0.65V.
Is it we need to initialize the ADS7843 using coding before we can use the PENIRQ?
Above coding is what i trying to use a LED to capture the PENIRQ pin.
Is there anyone can help me and give some advice?
Thank you,..
No touch on screen:
X+ = 2.315V
Y+ = 2.315V
X- = 0.000V
Y- = 0.000V
/PENIRQ = 3.3V
Touch on screen:
X+ = 2.315V
Y+ = 2.315V
X- = 2.315V
Y- = 2.315V
/PENIRQ = 3.3V
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 void GetScrXY(int *x, int *y) { unsigned char msb, lsb; // Get X coordinate CS = 0; dly(6); spi_write(0xD0); dly(80); // BUSY msb= spi_write(0x00); // msb lsb = spi_write(0x00); // lsb CS = 1; *x = (msb*0x100) | lsb; dly(100); // Get Y coordinate CS = 0; dly(6); spi_write(0x90); dly(80); // BUSY msb= spi_write(0x00); // msb lsb = spi_write(0x00); // lsb CS = 1; *y = (msb*0x100) | lsb; } void Check_PENIRQ(void) { int x,y; GetScrXY(&x, &y) ; if(PENIRQ) LED = 0; else LED = 1; }
Thank you,..
