[SOLVED] ADS2017 co-simulation error
Dmitrii
Vinnytsia, Ukraine
Hi, all!
I faced with the following error in ADS2017 during co-simulation:
--- ERROR ---------------------------------------------------------------------
A calibrated pin must not be positioned on an edge on which other pins are positioned. (Using a single calibrated pin simultaneously inseveral ports is also invalid in this respect.)
The pins involved are "Cs_P2" and "Rs_P2".
Please help me to resolve it.
  • Schematic.pdf
  • Layout.pdf
The problem is what the message says.
You need to create a little notch between the parallel pads. Or offset Cs a bit to the right side.
Reactions: Dmitrii
    Dmitrii
