pragash
Advanced Member level 2
hi all,
i supposed to set preprocessor settings following this procedure below but i cannot find preprocessor settings. please help.
Specify Preprocessor Settings
It is recommended that the user specified snap distance is set at 20 % of max trace Width (Max trace width:10 mil). For more information, see Defining Preprocessor Settings.
To specify Preprocessor settings:
1. Select EM> Simulation Setup to open EM Setup window.
2. Select Options in the left pane of the EM Setup window.
3. Click the Preprocessor tab in the EM Setup window.
4. Specify the User-defined snap distance as 20 % of the maximum trace Width.
5. Specify the arc resolution value, such as 60 degrees.
