[SOLVED] ADS Schematic Monte Carlo Simulation; Positive value for S12
noori.re
Member level 1
Member level 1
Dresden, Germany
Hello everyone,
Im doing Monte Carlo simulation on ADS schematic. I used Murata libray for non-resistive parts and for resistive parts I add the tolerances manually.
Every thing seems ok.
I run the MonteCarlo simulation of 5000 iteration.
In my results I got positive value for S12 and S21.
Is something run from my side or is it normal to get positive value in the MonteCarlo simulaiton?
How can I rely on this results when it gives some positive values for S12/S21?
Thanks
Positive insertion loss = gain for a passive component means your model and results are wrong.
You wrote that you added tolerances manually, so maybe you added them to the wrong model elements and allow negative resistance?
    noori.re
