ADS request: 4-port de-embedding model using TRL calibration
supersage
Member level 3
trl calibration code
Hi all,
In Agilent's application note "De-embedding Techniques in Advanced Design System" (page 32), ADS has a 'New' 4-port de-embedding component/model using TRL calibration standards for 4-port DUTs in non-coaxial environment (this model is created using C code). But it is not available as standard feature of ADS. Now I designed a coupled line structure and need to do measurement urgently. Do you have this component/model?
If you have it, could you please share this componen/model with me (my email: supersage001@hotmail.com)? Thanks a lot.
Best regards,
Kevin
Re: ADS request: 4-port de-embedding model using TRL calibra
Please, could you give more information about this stuff?
4-port de-embeding component is available as standard feature in ADS, we can find it in 'Data items' palatte. But this feature requires that the S parameters of feeding line be available.
In non-coaxial test environment, the S parameters of feeding line is usually not available, sometimes because there is not enough space for SMA mounting. Then TRL calibration scheme is proposed to solve this issue. In Agilent's application note (I mentioned above, and you could download on Agilent's website), a 'New' 4-port de-embedding component is proposed for TRL calibration standards, but is not available as standard feature in ADS.
So I am wondering if somebody could help me find this component in your advanced ADS. Thanks.
