arc resolution ads mesh
The structure is a ring-like microstrip structure with a 90-degree tight coupled curves whose spacing is 0.23mm.
Substrate:
1st layer - the above ring-like structure, 35um thickness, perfect conductor
2nd layer - rogers 5880 with 2 vias that are 2D distributed model,
3rd layer - infinite ground plane with an opening inside.
Mesh settings:
10cells/wavelength in 2nd and 3rd layer(no edge mesh), 20 cells/wavelength in 1st layer (automatic edge mesh)@ 2.5GHz and the arc resolution is 45 degree.
With the above settings, the mesh generation seems >>1.5 hrs.
I opened up the mesh report. There are multiple lines saying that
"Arc refacetting rejected. Refacetted arc violates original connectivity.
Arc: centre 0.000255241, -0.000100787 radius 1047.04 (in MIL)
Point of conflict: -436.393, 951.476 (in MIL)....."
With only 8 cells/wavelength for global mesh only took less than 30 seconds to finish.
Is there any ways to reduce the mesh generation time and still keep the simulation accuracy?
Thank you for your time and attention.
