ADS layout editing- how to cut portion of transmission line
accountme05
Newbie level 5
ADS layout editing...
hi every body!!
can any one tell, how can i cut some portion of transmission line in the layout,
i want to cut (remove) edges/corners of a rectangular stripline ...
shape is:
____________
|___________|
and i want
\__________/
i'm using ADS 2004A...
waiting...........
Select the corner points & move them.
there is option on upper right side, select corners,points etc.
You have to play little bit. its easy.
Rectangle will have 4 points and arbitrary shape given by you has more than 4points.
So you can not achieve in one shot. you need to do multiple commands.
Several Ways in doing this.
you can add another arbitrary circuit unite then and then shift as per Abhi guidelines.
