sonaiko
Junior Member level 2
adpll
Guys I am trying to implement ADPLL in verilog using Quartus-II so I can synthesis my model to an FPGA.
**broken link removed**I have found this code that implements an ADPLL designed by R.E.Best on 1999. I tried to simulate this code to test it but it is not working. Compliation OK but no simulation results. Only CK toogles but all other signals are at zero state.
Please help me figure this out. If this code doesnt work out I think I wont try to write my own code for a different ADPLL!
Thank you.
Thank you.
module pll (u1, u2, fc, reset);
parameter M = 5; //5 3
parameter N = 4; //4 2
parameter NF = 0; //0 1
input u1, fc, reset;
output u2;
wire FF1_in, FF3_in, MF_in, Start, CK, reset, Reset;
wire [N:0] Modulus_Control;
reg u1_star, Ud, Load;
wire u2, div_out;
reg u2_prime;
reg [N:0] N_Uf;
reg [NF:0] feedback_divider;
//*****PULSE FORMING CIRCUIT******//
inverter nt3(FF1_in, u1);
always @(negedge u1 or negedge reset)
begin
if(!reset) u1_star <= 0;
else u1_star <= !u1_star;
end
assign CK = u1 && u1_star;
assign MF_in = !u1_star;
mf mf1(.out (Start), .in (MF_in) );
//*****END PULSE FORMING CIRCUIT****//
jk jk1(.Q (FF3_in), .J (Start), .K (u2_prime), .reset (reset), .fc (fc) );
//jk jk1(.Q (FF3_in), .J (Start), .K (u2) );
always@(u2)
u2_prime <= u2;
always@(posedge u2 or negedge reset)
begin
if(!reset)
begin
u2_prime <= 0;
feedback_divider <= 0;
end
else
begin
feedback_divider <= feedback_divider + 1;
if(&feedback_divider) u2_prime <= !u2_prime;
else u2_prime <= u2_prime;
end
end
//*****DIGITALLY CONTROLLED OSCILLATOR****//
mcounter #(M) mc1(.u2 (u2), .div_out (div_out), .Reset (Reset), .reset (reset) );
ndivider #(N) nd1(.div_out (div_out), .Load (Load), .fc (fc), .Modulus_Control (Modulus_Control), .reset (reset) );
always @(posedge fc)
Load = div_out || Start;
assign Reset = Start;
//*****END DCO*****//
//***PHASE DETECTOR*****//
always@(posedge u1_star or negedge reset)
begin
if(!reset) Ud <= 0;
else Ud <= FF3_in;
end
//***END PHASE DETECTOR***//
//***LOOP FILTER***//
always@(posedge CK or negedge reset)
begin
if(!reset) N_Uf <= 6'b010000;
else if(Ud==0) N_Uf <= N_Uf+1;
else N_Uf <= N_Uf-1;
end
assign Modulus_Control = N_Uf;
//***END LOOP FILTER***//
endmodule
module mcounter(u2, div_out, Reset, reset);
parameter M = 2;
input div_out, Reset, reset;
output u2;
reg [M:0] value;
reg u2;
always@(posedge Reset or posedge div_out or negedge reset)
begin
if(!reset)
begin
value <= 0;
u2 <= 0;
end
else if(Reset)
begin
value <= 0;
u2 <= 0;
end
else
begin
value <= value + 1;
//if (value==5'b11111) u2 <= !u2;
if (&value==1) u2 <= !u2;
else u2 <= u2;
end
end
endmodule
module ndivider(div_out, Load, fc, Modulus_Control, reset);
parameter N = 2;
input Load, fc, reset;
input [N:0] Modulus_Control;
reg [N:0] value;
reg div_out_pre;
output div_out;
//always@(posedge Load or posedge fc or negedge reset)
always@(posedge fc or negedge reset)
begin
if(!reset)
begin
value <= 0;
div_out_pre <= 0;
end
else if(Load)
begin
value <= Modulus_Control;
div_out_pre <= 0;
end
else if(value != 0)
begin
value <= value - 1;
div_out_pre <= 0;
end
else div_out_pre <= 1;
end
assign div_out = div_out_pre;
endmodule
module jk (Q, J, K, reset, fc);
input J, K, reset, fc;
output Q;
reg Q;
reg Q1, Q2;
always@(posedge J or negedge reset)
begin
if (!reset) Q1 <= 0;
else if(K==1) Q1 <= !Q;
else Q1 <= 1;
end
always@(posedge K or negedge reset)
begin
if (!reset) Q2 <= 0;
else if(J==1) Q2 <= !Q;
else Q2 <= 0;
end
always@(Q1 or Q2)
begin
Q <= Q1 || Q2;
end
always@(posedge J or posedge K)
begin
if((J==0)&&(K==0)) Q <= Q;
else if((J==0)&&(K==1)) Q <= 0;
else if((J==1)&&(K==0)) Q <= 1;
else Q <= !Q;
end
endmodule
module mf (out, in);
input in;
output out;
wire flag, flag2;
reg out;
inverter nt4 (flag, in);
inverter nt5 (flag2, flag);
always@(in or flag2)
begin
if(!in) out <= 0;
else out <= in ^ flag2;
end
endmodule
module inverter (out, in); // inverter
output out;
input in;
reg out;
always @(in)
begin
#1 out <= !in;
//out <= !in;
end
endmodule
