ADM 3202 Rx Tx problem
absak
Junior Member level 2
Hi all,
I'm using ADM 3202 as TTL / RS 232 tranceiver, in fact i'm using only Rx Tx, VCC, GND pins of the ADM 3202 (pins 16, 15, 10, 9).
but when i connect the ADM to a 5 V power supply. (with V+ to vcc, V- to gnd), i'm retreiving 5V in the Rx Tx ????? (when the multimeter gnd is connected to V-)
can anybody have idea about this problem?
Regards,
absak
Did you connect the part according to the datasheet, including charge pump capacitors?
No i had only connected only transmitter, receiver, Vcc and Gnd pins. is there a problem if the charge capacitors are not connected, and where to connect them??
Regards,
thank you,
what is their role?
and where to connect theme if i want to use only Rx, Tx, Gnd, Vdd in my transmit / Receive
There role is in converting TTL level voltages to RS232 voltage levels. Whether you use only Rx or only Tx, for the Transreceiver to work you need them.
