sed_y
hi, consider the following mux code
this gives an error in xilinX ISE as
1)So, even after including numeric library, I cannot use '+' with std_logic?
2) so, do i need to convert to signed/unsigned and then add?
3) what is the safest way to use numeric libraries?
or
some authors say, unsigned library is not needed, others say, signed is not needed.
while some say, do not use std_logic_arith with signed/unsigned.
between numeric_std and std_logic_arith, one can make a choice based upon the operators defined. I believe, if more type conversions are needed, std_logic_arith would be better as it has more operator overloading, but it no Boolean operators?
4) The else clause covers other std_logic values. for synthesis point of view, suppose sel takes 'z', then too, y<-a+c. In real world application, would we do this, or write disconnect the mux by using something like
sid
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity examp1_pg165 is
Port ( a : in STD_LOGIC;
b : in STD_LOGIC;
c : in STD_LOGIC;
sel : in STD_LOGIC;
y : out STD_LOGIC);
end examp1_pg165;
architecture Behavioral of examp1_pg165 is
begin
y<= a + b when sel='1' else
a+c ;
end Behavioral;
+ can not have such operands in this context.
use IEEE.NUMERIC_STD.ALL;
a+c when sel ='0' else
'z';
sid
