Adding radiation boundary in HFSS
aiturri
radiation boundary
I´m trying to simulate spiral inductors with HFSS and I´m not sure about adding radiation boundary. I´ve simulated a very simple example with and without radiation and the results are very different! I don´t understand exactly what radiation boundary involves. Could anyone explain me sth about it???
thanks a lot
regards
amaya
Re: radiation boundary
anytime you simulate an open structure in HFSS
an external box that contains your device needs to be placed.
On the external surface you must assign
a Radiation Boundary.
If you do not apply Radiation boundarie, PEC boundaries is applied by default.
This means that you inductor is closed in a conductive box instead to be open.
Rugbyfun
    aiturri
When simulating spiral inductor you need to do the following:
1) The most important is the return path. Use a loop of perfect electric around the spiral that will be the reference ground. Connect lumped ports from the Spiral edges to the ground.
2) Take a very big air box (in all axis) with radiation boundaries. If you think the air box is too big you can reduce its size and compare the results.
The most important thing is to MODEL THE GEOMETRY YOU ARE DOING MEASUREMENTS ON.
Regards,
Itai
    aiturri
