Adding Parameters to mosfet in LTspice
Analogchips
Newbie
The article goes through addition of mos parameters like mobility, Cgs, Cgd, Lambda, Vt for mos models.
The difference between Level 1 & Level 2 transistor models is explained and a list of different transistor Level for different models is given.
You can understand which level to use for your simulation purpose.
Simulation and how to set it up is also explained and Level 1 & Level 2 difference is explained in table and simulation
https://gettinganaloged.wordpress.com/2025/02/23/adding-nmos-pmos-parameters-in-ltspice/
LaTeX Commands Quick-Menu:
