Adding Bonding PAD in encounter
dr.farnsworth
Member level 3
bonding pad add
Hello,
Could you please give some info, how bonding pads are added in encounter, i found how IO cells are placed using the io file. i was sucessful in placing IOCells,
but how to add Bonding Pads ??
Please help..
Regards,
Dr.farnsworth
encounter pin io file
Dear farnsworth:
You should use multi-row IO in encounter, I will show you the exact use!
The following syntax of I/O Assignment File allows you to create multiple I/O rows:
RowMargin: side <rowNumber> <offset>
Row: <rowNumber>
Indent: <length>
"RowMargin" specifies the I/O pad row margin, measuring from the die box inward, rather then
from the core box outward.
"side" Assigns a pin to the specified side of the design. Specify n (north), w(west),
s(south),or e(east).
"rowNumber" parameter specifies the row number, counting inward from the outer edge of the design.
"length" Indents the next pad or pin by the specified distance from the I/O pad row
determined by RowMargin.
Below example explains how to achieve double IO row:
Version: 2
RowMargin: s 1 0
RowMargin: s 2 200
RowMargin: w 2 300
RowMargin: e 2 400
Pad: c1 SW
Pad: c2 SE
Row: 1
Pad: pad1 s
Row: 2
Pad: pad2 s
Row: 1
Pad: pad3 s
Row: 2
Indent: 400
Pad: pad4 s
Row: 2
Pad: pad5 s
Pad: pad6 s
Pad: pad7 s
The floorplan should like:
|<---300--->|p2|p4|p5|p6|p7|<-----400--------->|row 2
|------------x--------x------------------------|
| c1 |<---x-->|p1 | 200 |P3 |<----x--->| c2 |row 1
------x-----------------------------------------
<---x---->
Note: The entire row area is distributed equally among the available IO Pad cell in that
row, such that they are placed at equidistance to each other.
bonding pad
thanks eminem198123 for the reply..
But the way you have described IO cells are added and may not be Bonding PAD in encounter..
i guess this terms little confusing whether we are talking abt IO Cells or Pad cells (Bonding Pad)
I have already added IOCells (which are also called IO PAD cells in the documentation)
