Adding assembly in c
namees22
Junior Member level 2
Ernakulam
hi
i am using RIDE ide..for programming 8052 i need to add some ASM codes to it.so some one pls help me in doing it.!
Kurenai_ryu
Advanced Member level 2
Bolivia
you can use the macro assembler ma51 and have your ASM functions coded in there...
or you can use the ASM pragma directive inside a C program...
/* example of RC51 file using ASM control */
main( )
printf("This program will indefinitely loop");
#pragma ASM
jmp $;
#pragma ENDASM
bigdogguru
Administrator
Southwest, USA
Actually the required techniques largely depend on the compiler in use, rather than the IDE.
If you are using the SDCC compiler, for example:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
unsigned char __far __at(0x7f00) buf[0x100];
unsigned char head, tail;
#define USE_ASSEMBLY (1)
#if !USE_ASSEMBLY
void to_buffer( unsigned char c )
    if( head != (unsigned char)(tail-1) )
        buf[ head++ ] = c;
#else
    c; // to avoid warning: unreferenced function argument
    __asm
        ; save used registers here.
        ; If we were still using r2,r3 we would have to push them here.
; if( head != (unsigned char)(tail-1) )
        mov  a,_tail
        dec  a
        xrl  a,_head
        ; we could do an ANL a,#0x0f here to use a smaller buffer (see below)
        jz   t_b_end$
; buf[ head++ ] = c;
        mov  a,dpl       ; dpl holds lower byte of function argument
        mov  dpl,_head   ; buf is 0x100 byte aligned so head can be used directly
        mov  dph,#(_buf>>8)
        movx @dptr,a
        inc _head
        ; we could do an ANL _head,#0x0f here to use a smaller buffer (see above)
t_b_end$:
        ; restore used registers here
    __endasm;
#endif
If you are utilizing another compiler other than SDCC, please specify and include version.
BigDog
