ederelk
my code compiles fine.but whenever i run the simulation in proteus it gives me error like stack overflow. but when i comment the statement in red it simulates fine without any error.please help me. :sad:
// Lcd pinout settings
sbit LCD_RS at RD2_bit;
sbit LCD_EN at RD3_bit;
sbit LCD_D7 at RD7_bit;
sbit LCD_D6 at RD6_bit;
sbit LCD_D5 at RD5_bit;
sbit LCD_D4 at RD4_bit;
// Pin direction
sbit LCD_RS_Direction at TRISD2_bit;
sbit LCD_EN_Direction at TRISD3_bit;
sbit LCD_D7_Direction at TRISD7_bit;
sbit LCD_D6_Direction at TRISD6_bit;
sbit LCD_D5_Direction at TRISD5_bit;
sbit LCD_D4_Direction at TRISD4_bit;
char* ValueRD;
char buf[15];
float data1=10.1234567891234;
float addme=2.0;
float newfloat=2.3 ;
char outBuff[21];
float xbuff;
float adc, adc2;
void StoreBytesIntoEEprom(unsigned int address, unsigned short *ptr, unsigned int SizeinBytes)
unsigned short j;
for (j = 0; j < SizeinBytes; j++)
EEprom_Write(address+j, *(ptr+j));
Delay_ms(50);
void ReadBytesFromEEprom(unsigned int address, unsigned short *ptr, unsigned int SizeinBytes)
unsigned int j;
*(ptr+j) = Eeprom_Read( address+j);
Delay_ms(50);
void Init_Main() {
TRISD = 0;
PORTD = 0xFF;
TRISD = 0xff;
//ANSEL = 0; // Configure AN pins as digital I/O
//ANSELH = 0;
ADCON1=7;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD display
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Lcd_Out(1,1,ValueRD); // Prepare and output static text on LCD
/* Delay_ms(8000);
Lcd_Out(1,1,gotbyte); */
// void WriteAndRead(){}
void main() {
// declare array
//WriteAndRead();
ValueRD="start";
Init_Main();
ADCON1=7; // Configure AN pins as digital I/O
delay_ms(100); //settle time for lcd
lcd_init(); // initialization of lcd
data1=newfloat + addme;
//ceil((double)data1);
delay_ms( 500);
// Lcd_Config(&PORTB,4,5,6,3,2,1,0);
LCD_Out(1,1,"Save to EEPROM:");
StoreBytesIntoEEprom( 0, (unsigned short *)&data1, 4);
FloatToStr( data1, &outBuff);
LCD_Out(2,1,&OutBuff);
Delay_ms(2000);
data1 = 0; // clear data, to see if it comes realy from eeprom back!
LCD_Out(1,1,"Get From EEPROM:");
ReadBytesFromEEprom( 0, (unsigned short *)&data1, 4);
FloatToStr(data1, &outBuff);
// Pin direction
char* ValueRD;
char buf[15];
float addme=2.0;
char outBuff[21];
float xbuff;
float adc, adc2;
unsigned short j;
Delay_ms(50);
unsigned int j;
Delay_ms(50);
void Init_Main() {
TRISD = 0;
PORTD = 0xFF;
TRISD = 0xff;
//ANSELH = 0;
ADCON1=7;
/* Delay_ms(8000);
void main() {
// declare array
//WriteAndRead();
ValueRD="start";
Init_Main();
delay_ms( 500);
Delay_ms(2000);
