Add in pci card design (on PCs PCI slot)...?
bulerias1
Member level 2
i designed some kind of verilog core,and i want to test it with PC.
i want to build such a card,with PCI BRIDGE,and FPGA for my core.
can someone help with this?
is there any reference design available?
what about the drivers to the PC-PCI,where to receive them,how to use them?
what is the best and fast GUI software to support this application?
i will apriciate any help...
thanks,
Bull
penrico
Full Member level 5
Argentina
For driver, best is windriver, take a look at jungo software, I think it have a free demo to use with PCI.
zape
Full Member level 2
Spain
I have used a development board from Insight electronics. Is called SPartan II-PCI or sthg so. It is about 2000$ and you have reference designs including some sw applications. If your application is similar to the reference design you may use their driver, if not, I used WinDriver as recommends "penrico" and it is quite easy and they provide you an user interface that helps you to debug your hardware.
