add cmos s and noise parameter in AWR design environment
eses23
Newbie level 6
I want to add 0.18um cmos in AWR. But I can't find any library or parameters. How can I add any Cmos process in AWR ? Please help :-?
Just add model parameters for 180nm from TSMC. Import it to AWR via netlist. Then draw a subcircuit and set an appropriate symbol for your transistor.
You can get the Spice model parameters here: http://gram.eng.uci.edu/faculty/green/public/courses/270c/homework/models/tsmc_180nm.txt
Hi cannibol_90,
I have a similar problem as eses23. I have the HSPICE netlist for TSMC's 28nm pdk. It contains the BSIM4 (v4.5) models for all of the nmos and pmos devices plus everything else in the kit. It's over 330,000 lines long, hundreds of librarys, subcircuits, models, and thousands of equations and variable references. When I try to import it into AWR, it cannot parse. Even if I pull out a single nmos model, I get errors everywhere. No one at AWR can help...and AWR does not have NDA's setup with TSMC or Global foundries.
I'm trying to design a switched capacitor PA using either IBM's 45nmSOI or TSMC 28nm in AWR. I do not have Cadence myself, but obtained the netlist from another source.
Any ideas?
I followed the AWR manual for importing the netlists to AWR. You have to add additional commands so that AWR can parse the model parameters. https://awrcorp.com/download/faq/english/docs/Users_Guide/importing_netlists.html
Try importing the TSMC 180nm model parameters with the .subckt command shown below. It worked for me. I have added flicker noise parameters too. Not the original one from foundry, but has been added to simulate phase noise.
* DATE: May 21/09
* LOT: T92Y WAF: 9103
* Temperature_parameters=Default
.SUBCKT MyPMOS 2 1 3 4 W=3u L=0.18u
M1 1 2 3 4 CMOSP W=W L=L
.MODEL CMOSP PMOS ( LEVEL = 49
+VERSION = 3.23 TNOM = 27 TOX = 4.1E-9
+XJ = 1E-7 NCH = 4.1589E17 VTH0 = -0.3823437
+K1 = 0.5722049 K2 = 0.0219717 K3 = 0.1576753
+K3B = 4.2763642 W0 = 1E-6 NLX = 1.104212E-7
+DVT0W = 0 DVT1W = 0 DVT2W = 0
+DVT0 = 0.6234839 DVT1 = 0.2479255 DVT2 = 0.1
+U0 = 109.4682454 UA = 1.31646E-9 UB = 1E-21
+UC = -1E-10 VSAT = 1.054892E5 A0 = 1.5796859
+AGS = 0.3115024 B0 = 4.729297E-7 B1 = 1.446715E-6
+KETA = 0.0298609 A1 = 0.3886886 A2 = 0.4010376
+RDSW = 199.1594405 PRWG = 0.5 PRWB = -0.4947034
+WR = 1 WINT = 0 LINT = 2.93948E-8
+XL = 0 XW = -1E-8 DWG = -1.998034E-8
+DWB = -2.481453E-9 VOFF = -0.0935653 NFACTOR = 2
+CIT = 0 CDSC = 2.4E-4 CDSCD = 0
+CDSCB = 0 ETA0 = 3.515392E-4 ETAB = -4.804338E-4
+DSUB = 1.215087E-5 PCLM = 0.96422 PDIBLC1 = 3.026627E-3
+PDIBLC2 = -1E-5 PDIBLCB = -1E-3 DROUT = 1.117016E-4
+PSCBE1 = 7.999986E10 PSCBE2 = 8.271897E-10 PVAG = 0.0190118
+DELTA = 0.01 RSH = 8.1 MOBMOD = 1
+PRT = 0 UTE = -1.5 KT1 = -0.11
+KT1L = 0 KT2 = 0.022 UA1 = 4.31E-9
+UB1 = -7.61E-18 UC1 = -5.6E-11 AT = 3.3E4
+WL = 0 WLN = 1 WW = 0
+WWN = 1 WWL = 0 LL = 0
+LLN = 1 LW = 0 LWN = 1
+LWL = 0 CAPMOD = 2 XPART = 0.5
+CGDO = 7.82E-10 CGSO = 7.82E-10 CGBO = 1E-12
+CJ = 1.214428E-3 PB = 0.8461606 MJ = 0.4192076
+CJSW = 2.165642E-10 PBSW = 0.8 MJSW = 0.3202874
+CJSWG = 4.22E-10 PBSWG = 0.8 MJSWG = 0.3202874
+CF = 0 PVTH0 = 5.167913E-4 PRDSW = 9.5068821
+PK2 = 1.095907E-3 WKETA = 0.0133232 LKETA = -3.648003E-3
+PU0 = -1.0674346 PUA = -4.30826E-11 PUB = 1E-21
+PVSAT = 50 PETA0 = 1E-4 PKETA = -1.822724E-3
+NLEV = 2 EF = 1.152 AF = 1.052 KF = 8.262E-28)
.ENDS
* DATE: May 21/09
.SUBCKT MyNMOS 2 1 3 4 W=3u L=0.18u
M1 1 2 3 4 CMOSN W=W L=L
.MODEL CMOSN NMOS ( LEVEL = 49
+XJ = 1E-7 NCH = 2.3549E17 VTH0 = 0.3694303
+K1 = 0.5789116 K2 = 1.110723E-3 K3 = 1E-3
+K3B = 0.0297124 W0 = 1E-7 NLX = 2.037748E-7
+DVT0 = 1.2953626 DVT1 = 0.3421545 DVT2 = 0.0395588
+U0 = 293.1687573 UA = -1.21942E-9 UB = 2.325738E-18
+UC = 7.061289E-11 VSAT = 1.676164E5 A0 = 2
+AGS = 0.4764546 B0 = 1.617101E-7 B1 = 5E-6
+KETA = -0.0138552 A1 = 1.09168E-3 A2 = 0.3303025
+RDSW = 105.6133217 PRWG = 0.5 PRWB = -0.2
+WR = 1 WINT = 2.885735E-9 LINT = 1.715622E-8
+XL = 0 XW = -1E-8 DWG = 2.754317E-9
+DWB = -3.690793E-9 VOFF = -0.0948017 NFACTOR = 2.1860065
+CDSCB = 0 ETA0 = 2.665034E-3 ETAB = 6.028975E-5
+DSUB = 0.0442223 PCLM = 1.746064 PDIBLC1 = 0.3258185
+PDIBLC2 = 2.701992E-3 PDIBLCB = -0.1 DROUT = 0.9787232
+PSCBE1 = 4.494778E10 PSCBE2 = 3.672074E-8 PVAG = 0.0122755
+DELTA = 0.01 RSH = 7 MOBMOD = 1
+CGDO = 8.58E-10 CGSO = 8.58E-10 CGBO = 1E-12
+CJ = 9.471097E-4 PB = 0.8 MJ = 0.3726161
+CJSW = 1.905901E-10 PBSW = 0.8 MJSW = 0.1369758
+CJSWG = 3.3E-10 PBSWG = 0.8 MJSWG = 0.1369758
+CF = 0 PVTH0 = -5.105777E-3 PRDSW = -1.1011726
+PK2 = 2.247806E-3 WKETA = -5.071892E-3 LKETA = 5.324922E-4
+PU0 = -4.0206081 PUA = -4.48232E-11 PUB = 5.018589E-24
+PVSAT = 2E3 PETA0 = 1E-4 PKETA = -2.090695E-3
+NLEV = 2 EF = 0.907 AF = 0.9065 KF = 8.704E-29)
.ENDS
Hope this helps. :)
Reactions: eses23
    eses23
