ADC problem with MPASM & PIC12F675
eem2am
Banned
intio pic12f675 gpio4
Hello,
I am writing in MPASM for PIC12F675.
My code builds fine but does not work properly.
I am using the ADC to read analog inputs on AN0 and AN1 in a loop.
Eg….Basically kind of like…..
Loop:
Read AN0
Read AN1
Goto Loop
Anyway, what actually should happen is that if the Analog conversion value in ADRESH is greater than 0x7F for the AN0 reading, then GPIO2 is taken high….if lower, GPIO2 is taken low
And if the analog conversion value in ADRESH is greater then 0x7F for the AN1 reading, then GPIO4 is taken high….if lower, GPIO4 is taken low
However, the readings are always taken from AN1, and even though I change the channel to AN0 it still only reads AN1.
I know the AN0 channel works as I got it working in a different bit of code.
So does any reader know why I can’t change channels from AN1 to AN0 and read the analog input there in my loop ?
Here is my code…………….
;PIC12F675
;MPASM assembler
;MPLAB 8.10
;Programmer = Pickit2
;Application version 2.11.00
;Device File Version 1.12.00
;OS Firmware version 2.20.01
;Internal Oscillator at 4MHz
;PIN USAGE
;AN0 = analog input;
;AN1 = analog input;
;RA2 = digital output;
;RA4 = digital output;
;RA5 = digital input;
#include <p12f675.inc>
	LIST   P=PIC12F675
	__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BODEN_OFF & _CPD_OFF)
cnt0		equ		0x20
cnt1		equ		0x21
cnt2		equ		0x22
cnt3		equ		0x23
ccd0		equ		0x24
val0		equ		0x25
val1		equ		0x26
ded0		equ		0x27
ded1		equ		0x28
BANK0	macro
	bcf		STATUS,RP0
	endm
BANK1	macro
	bsf		STATUS,RP0
	endm
FET_ON	macro
	bsf		GPIO,2
	endm
FET_OFF	macro
	bcf		GPIO,2
	endm
ENABLE	macro
	bsf		GPIO,4
	endm
DISABLE	macro
	bcf		GPIO,4
	endm
ENABLE_ADC	macro
	bsf		ADCON0,0
	nop
	endm
DISABLE_ADC	macro
	bcf		ADCON0,0
	nop
	endm
ADC_CH0		macro
	bcf		ADCON0,3
	nop					;nop to avoid RMW problem
	bcf		ADCON0,2
	nop
	endm
ADC_CH1		macro
	bcf		ADCON0,3
	bsf		ADCON0,2
	nop
	endm
DO_ADC		macro
	bsf		ADCON0,1
	nop
	endm
	org 0
	goto Start
Start:
	FET_OFF
	DISABLE
	BANK1
;Set up ANSEL register (set analog/digi ports
;..set up AD conversion clock)
	movlw	0x63
	movwf	ANSEL
;Sort comparator reference out even though
;i dont want to use the comparator
	movlw	0x00
	movwf	VRCON
	movlw	0x2B
	movwf	TRISIO
	BANK0
;Disable interrupts as i don't want to use them
	bcf		INTCON,GIE
	bcf		PIR1,ADIF
;Sort comparator out even though i dont
;want to use it.
	movlw	0x06
	movwf	CMCON
;The comparator ref must still be enabled
;even though i dont want to use the comparator
	BANK1
	bsf	VRCON,VREN	;Enable comparator ref
	BANK0
;Set up ADCON0 = Ljust; Vdd = ref; xx; CHS = 00; GODONE; Disable
	movlw	0x00
	movwf	ADCON0
	ENABLE_ADC
	FET_OFF
	DISABLE
;VVVVVVVVVVVVVVVVVVVVV
;* MAIN PROGRAM LOOP *
loop:
;Do ADC on channel 0
	bcf		PIR1,ADIF
	nop
	DISABLE_ADC
	ADC_CH0		;Change ADC channel
	ENABLE_ADC
	call	ADC_channel_changeover_delay
	D0_ADC
egg:
	btfsc	ADCON0,1
	goto	egg
	movf	ADRESH,0
	movwf	val0
	movlw	0x7F
	subwf	val0,0
	btfsc	STATUS,C
	FET_OFF
	movlw	0x7F
	subwf	val0,0
	btfss	STATUS,C
	FET_ON
;Do ADC on channel 1
	bcf		PIR1,ADIF
	nop
	DISABLE_ADC
	ADC_CH1		;Change ADC channel
	ENABLE_ADC
	DO_ADC
dog:
	btfsc	ADCON0,1
	goto	dog
	movf	ADRESH,0
	movwf	val1
	movlw	0x7F
	subwf	val1,0
	btfsc	STATUS,C
	DISABLE
	movlw	0x7F
	subwf	val0,0
	btfss	STATUS,C
	ENABLE
	goto	loop
;* END OF MAIN PROGRAM LOOP *
ADC_channel_changeover_delay:
	movlw	0x0F
	movwf	ccd0
fff:
	decfsz	ccd0,1
	goto	fff
	retlw	0x00
	end
I am very grateful for your attentions
pic12f675 examples
hi,
Only been able to look at your code, which is in a very small loop reading the two adc and switching your ports accordingly, but with the only delay being 50us, how can you 'see' what is actually happening ?
pic12f675 adc
thankyou wp100,
i can see what is happening with my voltmeter probing the ports GPIO2 and GPIO4.
The outputs on these ports depends on whether or not the ADC readings from channels 0 and 1 was greater or less than 0x7F (considers ADRESH only)
Unfortunately, the ADC module only reads from channel 1 and never switches over to channel 0
pic12f675 analog comparator
Yes, have followed your code logic again , looks fine but cannot spot any error.
Unable to actually run your code as my dev board is down at the moment.
Think going back a step and try running it with only adc 0 and then adc 1 to see if that works in this program code - think its just one of those frustrating silly one liner mistakes you just cannot see at the moment.
good luck
pic analog input assembly mpasm
thankyou wp100, actually i have a copy/paste error on the 13th line up from the bottom...."val0" should be "val1" but even with this corrected it still doesnt work.
basically all i need to do is to be able to switch adc channels.
here is the corrected code which doesnt work (wont switch adc channels)
;PIC12F675
;MPASM assembler
;MPLAB 8.10
;PIN USAGE
	LIST   P=PIC12F675
cnt0		equ		0x20
cnt1		equ		0x21
cnt2		equ		0x22
cnt3		equ		0x23
ccd0		equ		0x24
val0		equ		0x25
val1		equ		0x26
ded0		equ		0x27
ded1		equ		0x28
;   *** DECLARE MACRO'S ***
BANK0	macro
	bcf		STATUS,RP0
	endm
BANK1	macro
	bsf		STATUS,RP0
	endm
FET_ON	macro
	bsf		GPIO,2
	endm
FET_OFF	macro
	bcf		GPIO,2
	endm
ENABLE	macro
	bsf		GPIO,4
	endm
DISABLE	macro
	bcf		GPIO,4
	endm
ENABLE_ADC	macro
	bsf		ADCON0,ADON
	nop
	endm
DISABLE_ADC	macro
	bcf		ADCON0,ADON
	nop
	endm
ADC_CH0		macro
	bcf		ADCON0,CHS1
	bcf		ADCON0,CHS0
	nop
	endm
ADC_CH1		macro
	bcf		ADCON0,	CHS1
	bsf		ADCON0,	CHS0
	nop
	endm
DO_ADC		macro
	bsf		ADCON0,1
	nop
	endm
; *** MACRO'S NOW DECLARED ***
	org 0
	goto Start
Start:
	BANK1
	movlw	0x63
	movwf	ANSEL
	movlw	0x2B
	movwf	TRISIO
	BANK0
	bcf		INTCON,GIE
	bcf		PIR1,ADIF
;turn comparator off
	movlw	0x07
	movwf	CMCON
	BANK1
	bcf	VRCON,VREN	;disable comparator ref
	BANK0
	movlw	0x00
	movwf	ADCON0
	nop
	ENABLE_ADC
	FET_OFF
	nop
	DISABLE
loop:
	bcf		PIR1,ADIF
	nop
	DISABLE_ADC
	ENABLE_ADC
	D0_ADC
egg:
	btfsc	ADCON0,1
	goto	egg
	movf	ADRESH,0
	movwf	val0
	movlw	0x7F
	subwf	val0,0
	btfsc	STATUS,C
	FET_OFF
	movlw	0x7F
	subwf	val0,0
	btfss	STATUS,C
	FET_ON
	bcf		PIR1,ADIF
	nop
	DISABLE_ADC
	ENABLE_ADC
	DO_ADC
dog:
	btfsc	ADCON0,1
	goto	dog
	movf	ADRESH,0
	movwf	val1
	movlw	0x7F
	subwf	val1,0
	btfsc	STATUS,C
	DISABLE
	movlw	0x7F
	subwf	val1,0
	btfss	STATUS,C
	ENABLE
	goto	loop
	movlw	0x0F
	movwf	ccd0
fff:
	decfsz	ccd0,1
	goto	fff
	retlw	0x00
delay:
	movlw	0xFF
	movwf	cnt1
mog:
	movlw	0xFF
	movwf	cnt1
hog:
	decfsz	cnt1,1
	goto	hog
	decfsz	cnt0,1
	goto	mog
	retlw	0x00
	end
[code*]
p=12f675 adcon adcon0
Still not spotted any real error then .. think if you simply remove just the code below so if runs just on adc channel 0 and then see it that works, if ok then remove adc channel 0 code and then try on just channel 1 and see if that works.
Hopefully that should show up something -
Just a little thing might help with your coding, makes it easier to follow, when you have Subwf val0, 0 is easy to misread things - making it ( and similar instructions) .. val0,W or F, instead of 0 or 1, is less prone to errors.
bcf PIR1,ADIF
nop
DISABLE_ADC
ENABLE_ADC
DO_ADC
dog:
btfsc ADCON0,1
goto dog
movf ADRESH,0
movwf val1
movlw 0x7F
subwf val1,0
btfsc STATUS,C
DISABLE
movlw 0x7F
subwf val0,0
btfss STATUS,C
ENABLE
bug adc pic 12f675
If you look at your code in Mplab - you have three lines of " DO_ADC " the actual macro, and the two macro calls -
bcf PIR1,ADIF
nop
DISABLE_ADC
ENABLE_ADC
D0_ADC : **
Is this ** line in column 1 ? - bet it is - then it builds ok - but its only using it as a label not a macro call - will let you spot the error in your code ..
Don't worry -we all all do similar errors
:D
pic12f675 adc adresl
Hi all
I new member in this forum. i from malaysia. i new in pic12f675. i already have PICSTART plus, PIC12F675 & MPLAB IDE v8.3 software. I want to get knowledge from this furom. Hopefully i get it. So, now i searching simple assembly code for this PIC. Can u give me simple code. as example is LED blinking.
thanks
pic12f675 adcon0 c
You will find lots of tutorials and code examples in this and other forums - many are based on the 16F chips but you should be able to use the methods on the 12F chip.
This site has a very good reputation and the guy is contactable
http://www.winpicprog.co.uk/pic_tutorial.htm
pic12f675 assembler
sasuke_ninchan said:
Hi all
thanks
You should try Gooligum electronics tutorial.
www.gooligum.com.au/tutorials.html
pic12f675 example assembler
eem2am said:
Hello,
I don't know assembly but had worked on a similar project on the same chip, in C. here is my code and hopefully it is of value to you.
#include <htc.h>
// hardware configuration
#define Vin_a		GPIO0	//analyg in on GPio0;
#define CSPin		GPIO1	//current sense pin on GPIO1;
#define OUTPUT		GPIO5	//led out on gpio5;
// end hardware configuration
#define GETBIT(var,bit) (((var)>>(bit))&1) 		/* read bit from var */
#define SETBIT(var,bit) ((var)|=(1<<(bit)))		/* set bit from var to 1 */
#define CLRBIT(var,bit) ((var)&=(~(1<<(bit))))	/* clear bit from var (set it to 0) */
#define Vcs_th		((long) 125*1023/5000)		//input voltage threshold (125mv) to turn on the LED. from 0-1023 (10bit adc)
#define wait2		NOP();NOP()
#define wait4		wait2;wait2
#define wait8		wait4;wait4
#define wait16		wait8;wait8
#define wait32		wait16;wait16
#define wait64		wait32;wait32
#define wait128		wait64;wait64
#define wait256		wait128;wait128
#define adc_bits	7							//how many bits in pwm stepping
#define PWMLength	(1<<adc_bits)				//total length of pwm, should be consistent with sampling bits - 10 here
#define CSRemedy	OUTPUT=OFF
#define ON			0							//output high for ON
#define OFF			1							//output low for OFF
#define Tosc8		0b0010000					//ADC at 1/8th Tosc
#define Tosc16		0b1010000					//ADC at 1/16th Tosc
#define SEL_AN0		CHS1=0; CHS0=0				//select AN0 for ADC
#define SEL_AN1		CHS1=0; CHS0=1				//select AN1 for ADC
int ADC(void) {									//adc the currently selected channel
	GODONE=1;									//start the adc process on
	while (GODONE)
		;										//wait for adc to complete
	return (ADRESH<<8)+(ADRESL);
__CONFIG(MCLRDIS & INTIO & WDTDIS & BORDIS);
void
main(void)
	int Vin_d;				//adc result for Vin_a
	int Vcs_d;				//adc results for Current Sensor
	int i=0;				//where we are in length?
	//OSCCAL=_READ_OSCCAL_VALUE();
	CMCON=7;				//turn off comparators;
	TRISIO=0b11;			//input on GPIO0 and GPIO1, all others digital output;
	//set up ANSEL register
	ANSEL=Tosc8;			//Adc speed setting
	ANS0=1;					//GPIO0 is analog input;
	ANS1=1;					//GPIO1 is analog input;
	//set up ADCON register
	ADFM=1;					//adc results right adjusted
	VCFG=0;					//use Vdd as reference voltage
	ADON=1;					//starts ADC
	OUTPUT=OFF;				//turn output off;
	while (1){
		//TODO Auto-generated main function
		SEL_AN1;						//select AN1 / GPIO1
		Vcs_d=ADC();					//Vcs stores the results;
		wait256;						//wait for the Chold capacitor to charge-up
		SEL_AN0;						//select GPIO0;
		Vin_d=ADC()>>(10-adc_bits);		//adc the current channel
		OUTPUT=ON; for (i=0; i<Vin_d; i++);
		OUTPUT=OFF; for (i=Vin_d; i<PWMLength; i++);
		//		wait8;							//wait to charge up Chold
