ADC output store in EEPROM and Display On LCD using 16F877A
shimanto
Bangladesh
displaying eeprom data on lcd
I need a program code which will take analog input voltage from channel 0 of PORTA, convert it to 10 bit digital binary number, store the number in EEPROM data memory. Take another input from same channel after 15 minutes and again save it to EEPROM data memory. When I press a switch connected with RC0, the LCD connected with PORTB begins to show the decimal value of the numbers present in the EEPROM memory. Please suggest a code for this design.
how to store the adc output
use AVR chip its easy to use
how to coding adc and lcd
what do you mean by "suggest a code" do you want us to do the labour work for you? you better try yourself if you find a problem in some part then ask for help.
16f877a eeprom
haaaaaaaa thats a nice reply straight from the heart:D
Added after 2 minutes:
buddy go for the PIC application notes they usually provide macros for
eeproms and adc's search for it
you will finf something really helpful
