ADC Input Buffer in 0.18um CMOS
ozgura2
Turkey
analog to digital converter input buffer
I want to drive the Bootstrapped Switch Track and Hold circuit for a 1.5Gs/s, 8 bit CMOS ADC. For 0.18um CMOS process, normal source follower buffer has linearity and gain drawbacks because MOS transistor's output conductance is strongly nonlinear for minimum device length. I tried to compensate the NMOS transistor's output conductance change by driving its drain with a PMOS source follower but I can not get a good performance. Also it seems very high tail current is needed to properly drive the bootstrapped switch. Is there any alternative buffer circuit with high speed, linearity and gain performance?
Thanks,
Ozgur
transistor buffer adc
At that frequency the only closed loop amp that has a
prayer, I think is a current-feedback amplifier. But on
Jazz 0.18 we see hundreds of MHz full power bandwidth
(in simulations), not GHz.
This is one of several reasons, why many ADCs do not
integrate the buffer amp - better it be left as Somebody
Else's Problem.
