ADC Help-Pickit2 Starter Kit Example
gamersat678
Junior Member level 1
For the past day I've been trying to get adc to work and generate a voltage reading (0-5v) using either pin ra0 or ra2. I just can't get my code to work. I'm programming in Mikrobasic. Does anyone have any source plus a simple circuit schematic to show me how this works, or example source that would work with the built in parts of the pickit2 starter kit?
This is what I have.
program ADC
dim adc_rd as word
main:
    ANSEL  = 0xff           ' Configure AN2 pin as analog
    TRISA  =%1111111         ' PORTA is input
    ANSELH = 0              ' Configure other AN pins as digital I/O
    TRISC  = 0
    TRISB  = 0              ' PORTB is output
    'ADCON1 = %01100000
  while (TRUE)
  'Read pin ra2
    adc_rd = ADC_Read(2)  '*5/1023    ' get ADC value from 2nd channel
    if adc_rd>1 then
       portc.1=1
    end if
    portc.0=1
    delay_ms(100)
  wend
    portc.0=0
end.
gamersat678
Thanks for the link! Didn't fix my problem though. But after 6 hours of educated guessing I changed the mcu clock frequency from 8mhz to 4mhz. The leds are blinking now (2nd example on your link). Did I have the value set to high, what is the standard value? Sorry I'm new to this stuff. Btw i have two chips 16f690,16f677 different mcu clock speeds for each?
Any code for getting a voltage?
Jack// ani
Advanced Member level 3
What is source of your uC clock? Are you using 8Mhz crystal or internal software configurable oscillator?
According to the datasheet both uC should work fine at 8Mhz, so my initial guess is there is something wrong with your clock source!
gamersat678
Wow I just checked again using 8mhz and the code decided to work again???
I guess my only question now is how do you make a voltage reader out of this?
program ADC_10
dim AD_Res as word
main:
TRISA  = %11111111       ' PORTA is input
TRISD  = %00000000       ' PORTD is output
ADCON1 = %1000010        ' PORTA is in analog mode,
                         '   0 and 5V are referent voltage values,
                         '   and the result is aligned right
eloop:
  AD_Res = ADC_read(0)   ' Execute conversion and store result
                         '   in variable AD_Res.
PORTD = Lo(AD_Res)       ' Display lower byte of result on PORTD
Delay_ms(500)            ' 500 ms pause
goto eloop               ' Repeat all
end.                     ' End of program
Jack// ani
I assume by voltage you are referring to decimal value of your input voltage. Basically you have to convert binary value obtained from ADC to floating decimal.
I don't know how you do that in BASIC, but here is how you that in C. I hope you can tweak to make it work in BASIC.
#include <16F877A.h>
#device ADC=10
#fuses XT,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock=4000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
void main()
   int16 value; //Value is a 10bit data sample
   float volts;
   setup_port_a(ALL_ANALOG); // All the 8 channels are analog
   setup_adc(ADC_CLOCK_INTERNAL); // Internal ADC Clock
   set_adc_channel(0); // RA0/AN0(Pin2) is analog input channel
   while(1)
      value=read_adc();
      volts=(float)value*0.0048828125; // 1024 discrete levels, 5/1024 = 0.0048828125
      printf("Voltage is : %3.3f\n",volts);// Print upto 3 decimal places
      delay_ms(500);
Good luck
gamersat678
So I think I got it.
program ADC_10
dim AD_Res as word
dim valu as byte
main:
TRISC  = %00000000       ' PORTD is output
eloop:
  AD_Res = ADC_read(0)'Lo(ADC_read(0))*-1/256*0.6/4.65'/1023*50   ' Execute conversion and store result
AD_Res=(Ad_Res*0.0048828125) '.00488 for 5v
valu=AD_Res div 1
Select Case valu
Case 4
     portc=0xff
Case 3
     portc.2=1
Case 2
     portc.1=1
Case 1
     portc.0=1
Case 0
     portc=%00000000
End Select
'PORTC = Lo(AD_Res)       ' Display lower byte of result on PORTD
But is there any reason why the volt reading would be off .068 volts per volt (voltmeter vs pic adc, .933v-1v, 1.871v-2v, 2.803v-3v)?
Also what does ADCON1 = %1000010 mean?
hugo
Full Member level 6
canada
program ADC_10
dim AD_Res as word
dim valu as byte
main:
eloop:
valu=AD_Res div 1
Select Case valu
Case 4
     portc=0xff
Case 3
     portc.2=1
Case 2
     portc.1=1
Case 1
     portc.0=1
Case 0
     portc=%00000000
End Select
Try this piece of code : // ( mikroC ) !!!
adc_value = read_adc();
Volts = 5000*adc_value;
Volts = Volts / 1024; // Voltage in mV
or this one :
mV = (adc_value * 5000) >> 10; // Voltage in mV
" Also what does ADCON1 = %1000010 mean? "
You have to read the datasheet for the PIC you're using ...
