ADC dynamic parameters test
nassim_el85
Member level 4
Hi
In testing the SNDR specification for an analog to digital converter, how can we choose the input signal amplitude, if the input dynamic range is limited?
should the input signal amplitude force to the full-scale anyway, or it can be reduced, achieving a better dynamic specification?
jiangxb
Full Member level 3
hangzhou, china
hi nassim_el85,
for a complete testing you can sweep the amplitude of input signal and plot the relationship of SNDR against amplitude.
nassim_el85
Member level 4
Hi
I want to plot SNDR versus an other parameter and I want to know for what input amplitude I should simulate the ADC? Which SNDR is more important for us? the maximum SNDR or the SNDR for full-scale input?
jiangxb
Full Member level 3
hangzhou, china
well, i think the maximum SNDR is more important. but in your case, you can select a input amplitude close to the input amplitude with which the maximum SNDR is obtained to reduce the testing time.
banihashemi
Newbie level 5
it is true to reduce the amplitute to 90% full scale.
