Let say I want to input 10,000 Hz signal 10 volts peak to peak. and Digitize it (using ADC0804) and then later, Using DAC IC to undigitize it and see at the end the input signal. This is the start.
Now things may change, this is a start, what about if I want two signals or more, it would be wise I may introduce a PLL (phase lock loop).
I am trying to simulate them. does Orcad have models for them (ADC 0804, and DAC IC's) and where?
