wlamers
- Joined
- Mar 18, 2013
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,326
Hello All,
I have a board with a switched mode supply and a post regulating LDO. Switch mode supply can be set to give max 6V (TI LMZ14201). The LDO is set to 3.3V (TI TPS7a4700). I also require a buffered DAQ that can generate 0-10V or +/-10V (providing >20mA). Therefore I was planning to use a single supply DAQ (on 3.3V) and an external op-amp. Although the op-amp requires a +/-15V supply.
My questions is what would be a suitable design to supply a DAQ (not necessarily the DAQ/op-amp combo I mentioned above). All ideas are welcome. I prefer to have as less as possible additional supplies. So ideally the 3.3v LDO is used as the main supply for the DAC and also the op-amp. Maybe multiplying the output voltage using a coil, like in galvanic isolated designs? Note that it is not required to generate negative voltages with the DAC.
Thanks for your input.
