Acuity RangeFinder 2500 Sensor
Rujul Desai
Junior Member level 2
Ahmedabad
hi,
anyone know that how many output voltages and current required on (Rx+,RX-,Tx+& Tx- pins)for AR2500 sensor ?
its datasheet shows only its operating voltages.
Thanks
KlausST
Super Moderator
Staff member
i don´t know your sensor, but maybe datasheet says about RS485 standard or similar, then this information is sufficient.
Klaus
Rujul Desai
Ahmedabad
hi,
ya its RS422 standrad used for output but i want to know output voltage , because on that basis i want to find RS422 driver.
Thanks
KlausST
Super Moderator
Staff member
if it has RS422 outputs, then you need a RS422 RECEIVER.
Any RS422 receiver should be able to receive the data.
Look for transmission speed, receiver side power supply voltage, receiver side data voltage level.
But these information the sensor´s datasheet can´t tell.
Klaus
KlausST
Super Moderator
Staff member
so from where i can get this information?
1) wikipedia "RS422", if not directely fond on the page, then follow the links to the specifications.
2) google "RS422 levels" or "RS422 specification"
3) any RS422 transmitter/receiver datasheet
you only need to read one source of these thousands...
Klaus
