abicash
Member level 3
Hi
I am trying to figure out specs to design the following active load circuit to drive a controlled current through a resistive load.
Load resitance : 50 ohms
Current through Load : 10A dc (programmable from 1A to 10A)
Effectively V-Load min : 500 Vdc
Max time of current flow : 1 second
I am trying to design such a circuit as per the attached schematic.
The first stage of the opamp sets the current reference obtained from a microcontroller DAC output.
The second stage is the actual drive and compares the instantaneous current across the sense resistor with the set current.
I have trouble identifying a capable DC MOSFET (or number of parallel DC MOSFETS) with a good enough SOA.
IXTK8N150L is one which I found to be adequate and it has a SOA at 500V to be around 1A , @60C. So I would need at least 10 no's in parallel.
They would probably need separate drives for each.
Am I going in the right direction?
