Active 6Hz Bessel Lowpass filter Design
bessel lowpass
You could use Anadigm's FPAA device(switched-capacitor filter) to do this.
There is a free design software could help you design.
see www.anadigm.com
ynhe
bessel filter design software
Oh I am sorry, I forgot to mention switched-capacitor are very-prone to aliasing. The reason I am choosing Bessel Filters for their excellence in phase-linearity.
Ynhe. many thanks. I did not know this kind of software.
.Nice to know
filter 6hz
I just designed your 6Hz Bessel Lowpass filter using switched-capacitor,
The sampling frequency is about 0.5kHz that is much bigger than your corner frequency 6Hz.So. no aliasing.
ynhe
bessel lowpass filter
linear Technology makes ICs with many filter responses. They also give away a design program for selecting the external resistors and capacitors. They have different models with the clock frequency being different multiples of the filter bandwidth.
You could precede this filter by a wider bandwidth op amp one to remove the aliasing signals.
