mostafagb
Newbie level 1
- Joined
- Jan 16, 2010
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Bangladesh
- Activity points
- 1,319
.include "m8def.inc"
.cseg
.org $000
nop
RESET: rjmp STKINIT
.org $0012
rjmp TIMER1OVF ;to genertae 5-sec Time Tick using Timer-1 Overflow Interrupt
.org $0030
STKINIT:
ldi r16, 0x5F ; stack initialize
out spl, r16
ldi r16, 0x04
out sph, r16
L1: ;--Port-B Init--------
ldi r16, 0xD7; 1101 0111 ;
out ddrb, r16
ldi r16, 0x00
out ddrc, r16
ldi r16, 0xFF;
out ddrd, r16 ;11110000
TIMINIT: ;--- Timer-1 Initialization-- to generate 5-sec Time Tick from interna/ 1MHz/256
ldi r16, 0xF7 ; initial value for TCNT1L for 5sec
ldi r17, 0xC2 ; for TCNT1H
out TCNT1H, r17
out TCNT1L, r16
ldi r16, 0x00 ; configure normal T1 operation as upcounter
out TCCR1A, r16
ldi r16, 0x04 ; stopped internal clock /1024 for connection : use 0x05 to statrt Timer1
out TCCR1B, r16 ; Counter0 is started in Normal Mode
ldi r16, 0x04 ; 05 enables T1, T0 and 04 only for Timer-1
out TIMSK, r16
sei ; interrupt enabled
L2: ; CCTAB: ; cc-code table initialization 0060h - 006Fh
ldi r16, 0x3F ; cc0code of 0
sts 0x60, r16
ldi r16, 0x06 ; cc0code of 1
sts 0x61, r16
ldi r16, 0x5B ; cc0code of 2
sts 0x62, r16
ldi r16, 0x4F ; cc0code of 3
sts 0x63, r16
ldi r16, 0x66 ; cc0code of 4
sts 0x64, r16
ldi r16, 0x6D ; cc0code of 5
sts 0x65, r16
ldi r16, 0x7D ; cc0code of 6
sts 0x66, r16
ldi r16, 0x07 ; cc0code of 7
sts 0x67, r16
ldi r16, 0x7F ; cc0code of 8
sts 0x68, r16
ldi r16, 0x6F ; cc0code of 9
sts 0x69, r16
ldi r16, 0x77 ; cc0code of A
sts 0x6A, r16
ldi r16, 0x7C ; cc0code of b
sts 0x6B, r16
ldi r16, 0x39 ; cc0code of C
sts 0x6C, r16
ldi r16, 0x5E ; cc0code of d
sts 0x6D, r16
ldi r16, 0x79 ; CC-code of E
sts 0x6E, r16
ldi r16, 0x71 ; cc0code of F
sts 0x6F, r16
ldi r21, 0x00
sts 0x76, r21
sts 0x77, r21
rcall HEX2CC
HERE: rcall CCXPD
rjmp HERE
TIMER1OVF: ;----Timer-1 Overflow Interrupt----
ldi r21, 0x00
out TCCR1B, r21 ; Timer OFF
out TCNT1H, r17
out TCNT1L, r16 ;
ldi r21, 0x04
out TCCR1B, r21 ; Timer ON
;a -- indication of ISRT1---
sbi portb, pb0
rcall DELAY1
cbi portb, pb0
rcall DELAY1
rcall ACQ
sei
reti
ACQ: ;rjmp LQ
L3A: ldi r16, 0x80 ;ADEN=1,
out ADCSR, r16
L3AA: ldi r21, 0x40; r16, 0x40 ; 0100 0000 ref = Vcc
out ADMUX, r21; r16 ; ch-0
MDISP:
L3B: in r16, ADCSR
ori r16, 0x40 ; ADC is started
out ADCSR, r16 ; ADC is stared single conversion
AGNCHKX:in r16, ADCSR
sbrc r16, 4 ; skip next instruction if bit-4 of r16 is found cleared
rjmp RDADC
rjmp AGNCHKX
RDADC: in r16, ADCSR
andi r16, 0xFF ; resetting the ADIF-bit
out ADCSR, r16
;XL: ; --Input BIN-----
in r12, ADCL ; ldi r16, 0xFE ;in r18, ADCL
in r13, ADCH ;
LQ:
mov r21, r13
;ldi r21, 0x23
sts 0x76, r21
mov r21, r12
; ldi r21, 0x67
sts 0x77, r21
;--- converting Hex into CC7S codes----------
rcall HEX2CC
LQ1: rcall CCXPD
;rcall DELAY1
ret
HEX2CC: clr r27 ; x = r27, r26
clr r29 ; y = r29, r28
clr r31 ; z = r31, r30
ldi r26, $76 ; X = 0075h STAB
ldi r30, $84 ; Z = 0082h CCTAB
ldi r16, $02 ; 2 byte Hex to convert
AGN: ld r17, X+ ; r17 = 12 X points at STAB
mov r18, r17 ; r18 = 23
swap r17 ; 32
andi r17, 0x0F ; r17 = 02
ldi r19, 0x60
add r17, r19 ; r17 = 62
mov r28, r17
ld r17, Y ; getting CC-code from LUTAB
st Z+, r17 ; outting into CCTAB
mov r17, r18
andi r17, 0x0F ; r17 = 01
ldi r19, 0x60
add r17, r19 ; r17 = 61
mov r28, r17
st Z+, r17
dec r16
breq DONE
rjmp AGN
DONE: ret
CCXPD: clr r31
ldi r30, $84
ldi r16, $04
ld r17, Z+ ; DP0
out PORTD, r17
cbi PORTB, pb7
sbi PORTB, pb6
sbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP1
out PORTD, r17
sbi PORTB, pb7
cbi PORTB, pb6
sbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP2
out PORTD, r17
sbi PORTB, pb7
sbi PORTB, pb6
cbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP3
out PORTD, r17
sbi PORTB, pb7
sbi PORTB, pb6
sbi PORTB, pb2
cbi PORTB, pb1
rcall DELAY
ret
DELAY: ldi r17, 20
cag: ldi r18, 20
mag: dec r18
brne mag
dec r17
brne cag
ret
DELAY1: ldi r17, 10
cagainx:ldi r18, 10
magainx:ldi r19, 10
fagainx:dec r19
brne fagainx
dec r18
brne magainx
dec r17
brne cagainx
ret
.exit
.cseg
.org $000
nop
RESET: rjmp STKINIT
.org $0012
.org $0030
STKINIT:
out spl, r16
ldi r16, 0x04
out sph, r16
out ddrb, r16
ldi r16, 0x00
out ddrc, r16
ldi r16, 0xFF;
out TCNT1H, r17
out TCNT1L, r16
out TCCR1A, r16
out TIMSK, r16
sts 0x60, r16
sts 0x61, r16
sts 0x62, r16
sts 0x63, r16
sts 0x64, r16
sts 0x65, r16
sts 0x66, r16
sts 0x67, r16
sts 0x68, r16
sts 0x69, r16
sts 0x6A, r16
sts 0x6B, r16
sts 0x6C, r16
sts 0x6D, r16
sts 0x6E, r16
sts 0x6F, r16
ldi r21, 0x00
sts 0x76, r21
sts 0x77, r21
rcall HEX2CC
HERE: rcall CCXPD
rjmp HERE
ldi r21, 0x00
out TCNT1H, r17
out TCNT1L, r16 ;
ldi r21, 0x04
sbi portb, pb0
rcall DELAY1
cbi portb, pb0
rcall DELAY1
rcall ACQ
sei
reti
ACQ: ;rjmp LQ
out ADCSR, r16
MDISP:
L3B: in r16, ADCSR
rjmp RDADC
rjmp AGNCHKX
out ADCSR, r16
in r13, ADCH ;
LQ:
mov r21, r13
;ldi r21, 0x23
sts 0x76, r21
mov r21, r12
; ldi r21, 0x67
sts 0x77, r21
rcall HEX2CC
LQ1: rcall CCXPD
;rcall DELAY1
ret
swap r17 ; 32
ldi r19, 0x60
mov r28, r17
mov r17, r18
ldi r19, 0x60
mov r28, r17
st Z+, r17
dec r16
breq DONE
rjmp AGN
DONE: ret
CCXPD: clr r31
ldi r30, $84
ldi r16, $04
ld r17, Z+ ; DP0
out PORTD, r17
cbi PORTB, pb7
sbi PORTB, pb6
sbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP1
out PORTD, r17
sbi PORTB, pb7
cbi PORTB, pb6
sbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP2
out PORTD, r17
sbi PORTB, pb7
sbi PORTB, pb6
cbi PORTB, pb2
sbi PORTB, pb1
rcall DELAY
ld r17, Z+ ; DP3
out PORTD, r17
sbi PORTB, pb7
sbi PORTB, pb6
sbi PORTB, pb2
cbi PORTB, pb1
rcall DELAY
ret
DELAY: ldi r17, 20
cag: ldi r18, 20
mag: dec r18
brne mag
dec r17
brne cag
ret
DELAY1: ldi r17, 10
cagainx:ldi r18, 10
magainx:ldi r19, 10
fagainx:dec r19
brne fagainx
dec r18
brne magainx
dec r17
brne cagainx
ret
.exit
