guhapriya.sivasubramaniam
Newbie level 3
Hello,
I have designed a PCB for a boost regulator that converts 5V to 12V(40mA). There seems to be an acoustic noise in the board, ie, a humming noise in the board once the 12V supply is loaded with 300 Ω. There is no noise in unloaded condition.
A L-C LPF is used at the input point. When I test this LPF alone, I found that its noisy for a specific current rating(42mA), while when plugged into the rest of the ckt, it is noisy between (40 & 60)mA. The noisy also dies down when I increase (to 69uH) the shunting capacitance to ground.
L value - 22uH & C(original) value - 22uF.
Can someone explain me as to what is happening ?
