my problem was that (my ZG5 won't boot up, working with black screen)
so go to **broken link removed**
netbook-Aspire-AOA110 and download Download & Extract AS1_BIOS_3309.zip
People who still have this problem,(Acer Aspire One ZG5 won't boot up, working with black screen) this is what i did:
Download & Extract AS1_BIOS_3309.zip (from : http://support.acer.com/...
Rename the Bios name from 3309.fd to zg5ia32.fd.
Copy zg5ia32.fd and Flashit.exe to USB flash drive.
Start the restoration process:
A. Plug the AC Adapter into the unit.
B. Insert the USB flash drive into a USB port.
C. Press and Hold down the Fn and the Esc keys together.
D. Keep these keys held down and press power.
E. When the unit's power light comes on release the Fn and Esc keys.
F. After the keys have been released the power light will start to blink.
G. Let the unit run and after approximately 1-7 minutes, the unit should reboot.
H. Video should now be restored
these information is taken from this aser website: http://support.acer.com/...
i copied all three files: 3309.BAT, zg5ia32.fd , FLASHIT.EXE to root of my USB
you must also format your USB with fat file system (not fat32) with "Allocation unit size" set to "Default allocation size" before coping those three files
