sweethomela8
Member level 4
Hi, I have several voltage regulators on my board, what the the most accurate way of measuring independent current for each regulator? I had originally placed in a 0 ohm series resistor at the output of the regulator..that way I can always place in say a 1 Ohm in later and measure the voltage across the resistor and divide V/R for I.
But that may not be accurate...any better ideas? maybe use a breakout header and use a current meter to probe the output voltage and ground?
