Accessing usb drive on Vmware Linux on windows host
anoop12
Member level 5
I am using windows vista as a host OS. I have installed Redhat Linux as my virtual OS using VMWare. I am not able to access my pendrive on Linux .
I did mount it using mount command.
Any idea about this?
Thanks in advance
alexan_e
Administrator
Greece
Usually there is a tool in linux OS to mount or auto mount the USB drives but in any case the usb drive should be available in the file explorer as a drive, you can also check the /media folder and also open a shell and write dmesg to see if the drive has been recognized correctly.
Another option is to use shared folders to access the usb drive, uncheck the drive on the vmware virtual usb so that it is mounted in windows host,
then open VM -> settings -> options -> shared folders (vmware tools must be installed in linux to use this)
then add the windows letter for the usb drive as a shared folder, you can then access it in the /mnt folder
Alex
bluehole
Full Member level 6
Some where In INDIA
Thanks in advance
To access USB devices from VMware you must enable in Host side. That is you have to check some thing similar to "Enable resource" and then start the Linux as guest. It will find the USB.
