[SOLVED] Accessing Individual Bits mikroC pro for PIC Help me
nandana
I want to turn on LEDs on portb of 16f628A. I wrote following code. I need to make my program as following.
1. Turn off led (00000000)
2. After 1sec turn on PORTB.F1 (00000010)
3. then After 1sec turn on PORTB.F2 (00000110)
4. then After 1sec turn on PORTB.F3 (00001110)
5. then After 1sec turn on PORTB.F4 (00011110)
then loop back to Turn off led
but when simulating using isis,,,
every time only one LED is turning on. it is look like following
3. then After 1sec turn on PORTB.F2 (00000100)
4. then After 1sec turn on PORTB.F3 (00001000)
5. then After 1sec turn on PORTB.F4 (00010000)
could you please some one help me to solve this !! Why I cant Access Individual Bit without changing others.e
Edited
I have attached all files including isis.
I am using Mikroc pro for PIC v5.6.1
void main(void)
  CMCON=0x07;
  TRISB = 0x01;
do
  { PORTB=0;
         Delay_ms(1000);
     PORTB.F1=0;
         Delay_ms(1000);
     PORTB.F2=1;
         Delay_ms(1000);
     PORTB.F3=1;
         Delay_ms(1000);
     PORTB.F4=1;
         Delay_ms(1000);
   } while(1);
  • Accessing Individual Bits mikroC pro for PIC Help me.zip
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
void main(void)
  CMCON=0x07;
  TRISB = 0x01;
do
  { PORTB= 0b00000000;
         Delay_ms(1000);
     PORTB= 0b00000010;
         Delay_ms(1000);
     PORTB= 0b00000110;
         Delay_ms(1000);
     PORTB= 0b00001110;
         Delay_ms(1000);
     PORTB= 0b00011110;
         Delay_ms(1000);
   } while(1);
Hi what compiler you are using, try updating the full port...
Code C - [expand]
8
9
while(1){
    PORTB = PORTB | 0x00;
    shift = 0x01;
    for(i = 0, i < 3; i++){
        PORTB = PORTB | (shift << 1);
        Delay_ms(1000);
    PORTB = PORTB & 0b11100001;
i think jayanth in your for loop may be 3 to 4 right ya wrong please tell me!!!
in your do loop invert your values instead, if its on it turns off else off it turns on.
do
  { //PORTB=0;
         Delay_ms(1000);
     PORTB.F1= ~PORTB.F1;
         Delay_ms(1000);
     PORTB.F2= ~PORTB.F2;
         Delay_ms(1000);
     PORTB.F3= ~PORTB.F3;
         Delay_ms(1000);
     PORTB.F4=  ~PORTB.F4;
   } while(1);
Hi the mistake is
Code C - [expand]
PORTB = PORTB | (shift << i);
1 instead of i, and 3 instead of 5..
I wrote in binary because can be changed for any order of data.........
i think again trouble in for loop because first time i = 0 then PORTB | (shift<<i) result is 0x0000 0001 and this is not getting our original question . so start i = 1 to 5 is the desired result am i right ya wrong ?
exactly
Code C - [expand]
8
while(1){
    PORTB  = 0x00; // | changed
    Delay_ms(1000); // changed
     for(i = 0, i < 4; i++){ // 4 changed
        PORTB = PORTB | (0x02 << i); // i changed
        Delay_ms(1000);   // first delay for 0 value changed
Sorry for the mistake. Fixed code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
while(1){
    shift = 0x10;
        Delay_ms(1000);
    PORTB = PORTB & 0b11100011;
Initial state
PORTB = 0x00
shift = 0x10;
first loop of for, i = 0
    PORTB = 0x00 | (0b00000100) //PORTB = 0x10
second loop, i = 1
    PORTB = 0b00000100 | (0b00001000) //PORTB = 0b00001100
third loop, i = 2
    PORTB = 0b00001100 | (0b00010000)  // = 0b00011100 RB2-4 ON, RB0-1 OFF
Hi you put shift = 0x10 instead of 0b10 and 1 instead i and no delay for all 0 s and first time clearing port with | operator......
exactly
Code C - [expand]
8
while(1){
now that is ok and clear bro!!!!
I have edited post and attached all files including isis.
I need to control Individual Bits on portb without changing other bits of portb.
hey nandana have u tried post #2 or post #8 as venkadesh_M suggested or not ?
This method is also correct. But I need to Access Individual Bits.
Because I am going to make a latch type output controller. I have 4 outputs from another circuit and I want to give those to a 16f628a and then make latch type outputs. so I want to Access Individual Bits.
any help accept kindly. thank you
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
void main(void)
  CMCON=0x07;
  TRISB = 0x01;
do
         Delay_ms(1000);
     PORTB= 0b00000010;
         Delay_ms(1000);
     PORTB= 0b00000110;
         Delay_ms(1000);
     PORTB= 0b00001110;
         Delay_ms(1000);
     PORTB= 0b00011110;
         Delay_ms(1000);
   } while(1);
hi nick703
i tried #2.
that method is correct for control a byte. But I need to Access Individual Bits.
I haven't complete input part yet. Firstly I tried to make these out puts. Then I face this problem
u tried that type of code
void main(void)
  CMCON=0x07;
  TRISB = 0x01;
  PORTB=0;
do
         Delay_ms(1000);
     PORTB.F1=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
     PORTB.F3=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
     PORTB.F3=1;
     PORTB.F4=1;
         Delay_ms(1000);
   } while(1);
I tried this also. But every time after Delay only last command makes out put.
The problem is when I Access Individual Bits other all bits going to zero.
help me. If you can download my attached file, then you can see the result.
Help me.!!
And thank you very much for waiting your valuable time for me.!!
void main(void)
  CMCON=0x07;
  TRISB = 0x01;
  PORTB=0;
do
         Delay_ms(1000);
     PORTB.F1=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
     PORTB.F3=1;
         Delay_ms(1000);
     PORTB.F1=1;
     PORTB.F2=1;
     PORTB.F3=1;
     PORTB.F4=1;
         Delay_ms(1000);
   } while(1);
Hi the problem is read modify write operation put a resistor between output and LED then the first program itself will work fine............
  • New folder (3).7z
